1 - 9 of 9 Posts
I painted one piece of the interior wood grain trim glossy black. It looks great but is a bit "bumpy". I wet-sanded with 2000 grit paper but all that did was smooth it nicely but it took off the gloss leaving scuff marks. So I re-painted it but won't go to the next step until I get some kindly advise on how to achieve that mirror finish. Or at least close to it. Thanks
Back in Black
good polish then buff it.
Wet sand then buff, should work out for ya. It may take a few coats of polish to get it there but it will work.
To be honest I wouldn't even mess with a clear coat on interior parts. Wet sand with 1k then 2k, clean, good polish and buff out. Use quality polish and nice rags/cloths.
That shit will rub off. Clear coat wont hurt and it will yield a better finish product
Not if you wax after :eek:k3:
Agreed a clear coat would be a better choice but, I have always had problems with a clear coat esp on smaller pieces.
Good prep and patience will yield a better end result. Why not give it your best if your going the extra steps to paint it, you will be more satisfied in the end...
Reactions: tonyc712000
1 - 9 of 9 Posts
