I have a 1977 firebird that has a 305 bored 30 over and want to put a set of 350 heads on it, will this work?? I have been told several different things, yes no maybe i don't know HELP
You need to check the block designation, and the head designation. Some parts can be swaped in that manner. You also need to check the type of piston you are using, and the valve geometry to make sure there is no parts contact.
Compression ratio is also going to be an issue, as will be the pushrod and rocker arm configuration. This is a swap best left to a really good mechanic unless you line up the parts through a good shop.
I'm not going to blow any GM web sites horn since there are so many out there. Just look for a nearby shop that has a web-site, and tell them what you have, and what you are looking to end up with. It should not take long, but may end up costing quite a bit.
I dont think the 305 will take the larger 2.02/1.60 valves. Not enough cylinder wall clearance.
