Guest
·i think the skirt would provide some problems if I got 22's
Yes.....if you have the correct backspacing and offset.
A 9" wide wheel with a 5.5" backspace will fit with no problem :wink: .
KW
Of course you can......if you can find tires that are 28" (in diameter) or shorter.
It's not the wheel size you need to worry about, it's the diameter (and to a lesser extent, the width) of the tires you need to deal with.
It's really that plain and simple.
KW
