2006 Impala, 3.5-L V6 Flex, 4 wheel ABS w/TC
I recently replaced all four tires, rotors, calipers, and pads.
Doing so has eliminated the dash notification regarding the "service brake assist" and "traction control."
After a local shop bled the ABS module I still had lack luster brakes.
I found the master cylinder was leaking in to the brake booster and have replaced them both.
After reassemble, I have noticed a very slight leak where the brake lines fit to the ABS module.
How do I determine if the issue is the module, the lines or both?
My last option at this point would be to replace all the lines and the module just to be safe than sorry..
