I blew a hole in the bottom side of the block of the 3.5 around cyl 3 in my 07. I found another 3.5 out of an 06 at a junkyard with around 80k miles. I’ve swapped engines before but I’m just wanting to know if there’s anything in particular I need to look out for when I’m swapping and also if it’ll be possible to remove it from the top because I don’t have a lift available and no way to tow it to a shop with a lift. Any help is appreciated!
