I'm having a similar problem. After trying a new switch, resistor/control module, and blower motor, I have it narrowed down to something messed up in the dash wiring. There is a harness that runs from the fan / vent switches and snakes somewhere down through to the 5-wire blower control module/blower motor. I smacked the dash between the ashtray and switch panel yesterday and it kicked back on after cutting out on me for a few minutes. I was not able to get to the wiring harness from the front of the dash. I am thinking I may have to go in from underneath somehow. The way I found out it was a wiring issue in the dash after attempted component replacement was that when it quit on me, I had the dash off and the switch panel sitting there unbolted turned to on, and I reached back into where the switch panel connects to a harness under the radio, wiggled the wires, and it kicked back on. It's still cutting out on me intermittently, so I'm not sure what the next step is. I can't track down a part number for the harnesses, some people have run a bypass to the hot red wire down going into the blower control module itself, but I'm not sure how they're splicing that in exactly, and I'm a little hesitant to do that in fear of shorting out something else.
