Blend door actuator replacement ... no calibration necessary
29K views 13 replies 7 participants last post by  bray996
There were software updates available in 2019 for the dual zone climate control head in my 2009. I've forgotten what the actual date was on the update. Probably much earlier.
I can't recall whether my Tech 2 has a re-calibration option in the HVAC menu on my Impala or my Silverado.
You need a Delco TDS Single VIN subscrtiption along with an MDI/MDI-II and a laptop or an SAE J2534 programming adapter for one of the higher $ higher end tools like the Autel Maxsys or Snap On or ... . A good MDI clone or MDI II clone can be had for under $400 but they only work on 1996 & newer GM models. Autel, Snap On, ... work on a wider range of vehicles but you'll pay dearly for one.
You can likely sell your MDI clone on evilbay if/when you sell your GM.
