I have a 77 2 dr and I am trying to install a 454 that I came across.Well I tried the stock mounts and the 454 mounts and neither bolt up correctly so,now I am at a stand still.Help please !!!!!!!!:frown:
You can have your motor mounts and tranny mount cut off and relocated and welded up for your application.Those mobile welders with rigs come to mind.Take the stock bbk mounts and have them welded to the frame.On a side note you have to measure somethings out if you go this route.DRIVE SHAFT and exhaust modifications..Also your exhaust manifold not effecting you steering rod to gear box.It can be done.Just my 2 cents...
