When you pull and push the light button back and forth..after the fourth or so time...the car makes a beep noise as if it acknowledges something or something has been changed....any idea what this is....
that's how you reset the tire pressure monitor-try it thru your radio, it should be the same beep
That wouldn't make sense. Because you can do it through the radio like you said but its the same beep noise as if you change any other settings through the radio....
I beileve it is just an alternate way of reseting it, since some people have an aftermarket radio or maybe all impalas didnt have the ability to reset dummy lights through the stereo.
just my 2 cents
correct me if im wrong.
