Today I lost the nut that held on to one of my battery terminal..
Long story short I went to autozone and pepboys. They have everything but the same exact one. The one that I lost is different than the ones they have in stock and I cannot find a replacement. So far the terminal bolt is being held on by two regular hex screws.. No problem yet but it is a bit loose if you apply a bit of pressure to move it. =/ I'm getting an headache looking around and failing. Any other solutions? If you have a 06 and above and ever fiddled with it look closely, its a bit different =[
Thanks
I would have just replaced both terminals or gone to a junkyard. A junkyard would likely just give the nut to you for free.
Next time just loosen it, but don't remove the nut. That's what I did when I changed my battery.
