Hey, just wondering how the auto heated seats work, i've been remote starting my 2018 impala LT with dual zone climate control in sub 0 weather (below 32 f). I was hoping someone would know; every time i got into my car the heated seat lights were out and they didnt seem very warm? is that normal?
Also unrelated when i have the climate system in auto is it normal the a/c light is always on i assume the a/c doesn't run non stop?
Thanks for the help :D
AC runs in cold weather to dehumidify the air.
Yep, just to answer the question if anyone else has it. The light stays on constantly when in auto but the a/c will run as needed. The light for the heated seats doesn't turn on but the heated seats do work when remote started, i don't know if it runs at full power but it does heat up.
Did you read your vehicle owner’s manual?
I have a 2014 Impala 2LTZ with the heated & cooled front seats. The feature to turn on the heated seats can be set via the settings in the touchscreen menu.
When the heated seats are activated via the remote start, the two console heated seat switch lights do not illuminate. When you push the start button, the heated seat feature is turned off - then must be manually turned on by pushing the switch on the console for the heated feature.
No i'm an idiot and sat in my car in the freezing cold after remote starting it to see if they warmed up.
I’m glad you said it.
It is not unusual for people to join this forum and post a question, which is answered in the vehicle owner’s manual.
In addition to asking if you read your manual, I posted information on how the heated front seat function operates on my Impala LTZ with the remote start feature (which should be very similar to your vehicle), and how to operate the heated seats once you enter the car and unlock the ignition system.
You’re welcome.
the AC light on is maddening for newbies to the car and i question to this day, the operation of this heating system. just hope your actuators dont play with your mind like they do with me. sometimes ill be in the car and after a while the temp swings one way or the other. but it generally works ok so i'm just used to fidding with the knob.silly me when i set a temp i expect the same temp of air consistently out of the vent.
one thing i cannot emphasize enough is change your cabin filter. i started a few threads on here asking about AC problems and turns out that my filter was so clogged, i wasnt getting the cold air. and no one here thought to even suggest that to me. so the smallest things can make a difference. now i freeze in the summer. not a bad thing.
dont expect much from the cooled seats. i still have sweaty back sometimes in summer. i think you gotta have air coming out the lower vents for this to work correctly
