1 - 10 of 10 Posts
We picked up a '17 LT over the summer and it has the stock 18" wheels on it. I found a set of 20" Camaro wheels local to me for a deal I just couldn't pass up. I know the bolt pattern is the same but I wasn't sure about the offset so I was interested to see if anyone has installed Camaro wheels on their Impala and how the fitment was.
The offset for the wheels I picked up are:
Front Wheel: 35mm
Rear Wheel: 40mm
If the fronts are 20x10 I believe they will be too big on that offset. 20x9.5 was the largest size without rubbing when I ordered my wheels last week. Check out willtheyfit.com
You should have no problem then the fronts will fit a 20x9.5 with a similar offset and the backs have plenty of space. You could always pull a wheel off and test fit before buying tires.
Staggered fitment from a Camaro can be problematic, a set of 4 front wheels or a non staggered set is your best bet. I ran a set of '14 SS 20" front wheels last summer.
Looks nice!
1 - 10 of 10 Posts
