I have a 2014 Limited with now almost 92,000 on it. I put just over 500 miles a week on it running back and forth to work. Other than synthetic oil changes, two transmission fluid drain and fills, 2 cabin filters, 2 air filters, 2 front hub bearings, and turning the front brake rotors, the car has been easy on the wallet in terms of maintenance. In the next month or 2, around 100,000 miles, I am going to change the antifreeze, spark plugs, brake fluid and check the belt. Still on the factory brakes, tires were replaced not too long ago along with an alignment and still on the original struts and all suspension parts, save for the Addco sway bar and bushings and Moog rear end links I installed when I got it (took them off the 2002 Grand Prix I traded in for the Impala).
The car has been great, no issues whatsoever. For the mileage I run, it is a good car to do it with. I am fanatical with maintenance and receipts and documenting it. If you can buy one with proof of maintenance, it is a no brainer.
