Amp/subwoofer install
3641 Views 7 Replies 8 Participants Last post by  DeuceLoco1a
I have a 2017 Impala LT w/out the Bose system. I've been looking to install a system in it. But this is my first new car installing a system w/out an aftermarket radio etc. So I need some help
1 - 8 of 8 Posts
Sorry no help here, been away from custom interiors and car audio for a good while and would not be a lot of help but there are a couple guys here like tjhenry77 who are very sharp on car audio, maybe one of them will see this soon.
Probably would not hurt to ask any specific questions you have.
Are you just wanting to add a sub and amp but keep the rest of the system stock?
I did that to my 07 SS w/Bose. In that case, there was an opening in the rear deck that I used to mount the sub. I had to run power from the under the hood for the amp. For signals, I just tapped them off the rear 6x9's and fed them to the sub amp (in the trunk).
I haven't seen the underneath side of the rear deck in the epsilon-II Impalas, so I'm not sure what there is to work with there. But the hole in the rear deck of the w-body Impalas makes a nice place to mount a 10" sub. I don't have a pic handy of my 07 SS sub, but I've attached a pic of the one in my son's 2002 (gen7) Impala, which is pretty much identical. It shows the bottom side of the fixture. No finish was applied, but some folks might paint it to pretty it up a little :)
It's hidden on the top side, so no finish was necessary there.
HTH.
See less See more
if you want to add an amplifier and do it right youll need a sound processor that will take the factory signal and normalize it to allow it to be amplified correctly. Something like the jl Audio fix will do this quite nicely. They're cheaper options out there from sound control and a few other brands but the nice thing about the JL fix is that it gives you preouts as well. It allows full customization too. With jl quality. Any new car has a lot going on with the eq settings etc etc and this is necessary to make it sound right and not run into issues.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Just had this done on mine. Took it to a reputable shop and they used a line out converter to hook up my amp. Stock unit doesn't put out the best quality but keeps everything stock and nice. I would like to add though; I modified the rear center console access so that it could let some of the bass out therefore sounding better. Had to cut the carpet on the rear seat but part is replaceable along with the cover in case I want to put it back to stock. Still have to finish up the final cover, but all good for now.
You know where they ran the power for the converter
2
I have a lc7i for my output converter. What I did is I have distribution blocks for my 2 amps and I just ran the positive and the negative to the same distribution blocks but if you're not getting that serious into it you can always run it 2 the battery cigarette lighter or where you running your remote wire now.
163812
163814
See less See more
1 - 8 of 8 Posts
