Does anyone know how long should your amp ground wire be. I had a problem with my sub box and my ground to my amp sub came loose. I had someone run a fuse in between the ground wire and extend it some. I didn't have any noise before now I have a humming noise and a thump when I turn the car off. Could this happen because the ground is too long.
Amp Ground should only be around 2 feet or less
Reactions: Hill
That's what I thought. I also thought a certified installer would know that.
No fuse for ground, if it gets cut then all well. Positive gets cut then hopefully fuse will blow. 2nd the 2ft or less.
OEM LOL
Actually 18inches or less but 2 foot or less will work good.
Also should be 0 gauge wire but you should be fine up to 4 gauge.
And no fuse on ground only power and within a foot from the power source.
