1 - 20 of 24 Posts
I have an 04 impala, yesterday the windows rolled down, now all stopped working at same time. I saw in owners maual that a relay controls windows AND sunroof. the Sunroof still works. I dont know what else to check. Thanks
this may be a silly question, but are you trying to roll them up using the driver's master switch or have you actually gone to each door's switch too?
That's not a silly question because it would tell you if it's just the driver's door switch, which it very well could be, or something else.
:biggrin: That is a very common thing with people walking up to the parts counter trying to figure out why all of the windows wont work.
Discussion Starter #6
power window update
Sorry i havent gotten back sooner.......yes, all controls on all doors dont work. or should say didnt work. Heres the update. After removing relay and re inserting, the windows went back up, but stopped working again five minutes later, figured it couldnt be relay since power sun roof still works, noticed that when pushing on drivers side button I would hear a buzzing sound ,so i figured it being a bad switch, replaced switch and still same noise, put old switch back in and now windows are working "so far", went ahead and checked wiring in boot in door jam cause I heard that wire get broken, everything is OK there. So I dont dont know what else to do, just hope they dont stop working again when its supposed to rain I guess.
Discussion Starter #7
well that didnt last long. They stopped again. I dont know what else to check Switch is good ,relay good, dont see any broken wires in boot in door jam. Any Ideas
Discussion Starter #8
problem solved
Well I figured it out. The wires in the boot in door jam go into another connecter in dash. As I pushed and pulled on wires in the connecter the windows wood start and stop with every tug. So its just not connected good there. I will have to get under dash and remove some things in my way to get my hands on connecter to get wires tight.
You might want to spray some contact cleaner (Caig Deoxit is best) in the connector.
My favorite one is where you take it to the dealer, they replace relays, the driver's door switch and two of the power window motors and it still doesn't work, and THEN they spray the contact cleaner in there and the problem is solved.
Hi everyone, just signed up here because I'm having the same problem with the bad connection. Power is intermittent when I moved the wire loom from the door. I'm working on getting a voltmeter to track it down, but was wondering if the OP figured out which wire it ended up being so I can fix this now while its apart. Thanks for the help in advance.
Check in between the door for the wires running through. Pop out the rubber boot toward the door and slide inside the door so you can see the wires and check the black ground wire is most likely broken.
It is a broken wire in between the door and the fender. In that rubber boot. Check for a black wire. I have an 04 and impala and all my window stopped working at the same time with a buzzing noise. I fixed it today and now all of them are working
Same problem
I am at a loss at this point. I have checked all switches and replaced the drivers side/master switch. Windows do go up and down by the master switch, but will not roll down or up at the doors switches. I have made sure that the kid lock is in the right place. Tried that switch both ways. Any ideas you have will be gratefully.
Thanks
Thanks
Check for power at the dark blue wire in the 6way flat connector with key on. Check with lockout switch on and off. It should change when you change position of lockout switch. If it does its a wiring/connection issue, if it doesn't you've got a bad switch.
2002 chevy impala
if your window switch is buzzing then the black wire inside rubber boot is broken splice back together will work fine hope this helps
Snapped wire - Electric windows stopped
Same problem - all four windows stopped at the same time. After substituting fuse/relay (or whatever that box is) to no avail. and then buying a new quad control switch which also did not solve the problem, I (waited for the end of winter for a nice day) pulled the rubber boot back and found a YELLOW wire that had totally severed. It snapped right about half way through the rubber boot so I had to get a comparable gauge stranded copper wire, about 6 inches long, and solder it to one end, tape, then feed it through the boot and repeat the process on the other end. It's tight quarters but wasn't as bad as I'd feared. Good Luck.
i had the same problem until just now. no windows worked, buzzing in switch. inside rubber boot i found 3 wires broken. black wire fixed window problem completely, and i fixed an orange wire, and a grey wire. now the door lock switch locks the drivers door. it used to only lock all the other doors. bonus for me. BIG THANKS to all who commented on this!
1 - 20 of 24 Posts
