Does anyone know for sure if this part is covered under the emissions warranty?Veh is 2014 impala,49,000miles
Sent from my SM-G973U using Tapatalk
I have a 2014 Impala 2LTZ, purchased new. Last year, I noticed the same duct was split badly.
I do not know if the emissions warranty will cover the part, but you could call a dealership and ask.
I have a no-deductible GM platinum warranty which would have covered it. At the time, I did not want to make two trips to the dealer to have it diagnosed, ordered and replaced - so I bought a new one and installed it myself. It takes about 10 minutes.
Not sure if the replacement ducts you get from GM are of the same type of material but if it only took 40k miles to crack it I'd bet the OEM replacement will do the same. Ours was cracked as well. I ordered an aftermarket one and it's a very pliable rubber, much better than the harder compound rubber of the OEM unit.
