1 - 8 of 8 Posts
I just bought a 2018 Impala LT with LT1 Trim comes with 8 inch screen. It does not come with the Bose system. I need some help/answers. I want to add speakers to the rear deck and I don't need top notch speakers. I've searched online but have not found my answer. Also do I need an amplifier?
Thanks in advance.
Tito P.
Adding an amp will be needed
You’ll also need to find a signal source for the amp. Ideally ur rear speaker wires in ur doors
Also will need to run power wire to battery
Find a ground point for the amp
And install a remote turn on wire.
Run wires to speaker locations from amp
As u can see it’s pretty involved to dive into this idea
This will cost u about $250 on the cheap side but won’t sound great.
Honestly ur smartest bet is to throw in a small subwoofer to add flare to ur system
For complexity I would say about the same. But you’re going to notice much more of a better improvement on your stereo with their versus adding 6 x 9’s
If you have never done anything like this before I would highly recommend going to a car stereo shop and have them put it in for you it may cost considerably more for the labor but it’s going to be worth every penny then you know you For sure it’s done correctly
If u happen to be in the southeast wisconsin area I can take care of ya
1 - 8 of 8 Posts
