I have a 2019 LT and I was able to successfully add the ambient lightning to the front doors as the applique panels just switch in and I had the harness from the donor car. My question is for the dash did they only put the ambient lightning in cars with the CD player? If so how do I go about adding the CD player into my car so that when I do find the applique panels for the dash I can get everything and do it all at once.
It’s just like changing a door speaker except for you don’t touch the speaker. After the door is pulled there’s a handful of screws that hold the trim on. Insert the new trim piece, disconnect the old harness and remove it from the door panel, install the new harness in the same hold down spots and plug everything in and you’re good to go. Takes 10 minutes per side.
