Hi. I just inherited a 2001 base model Impala.It did not come equipped with keyless entry. what would be the cheapest/easiest way to add this feature? thanks for any tips.
An aftermarket unit.
I eat brains... gimme brains!
It should have keyless entry, you would need to use your VIN number to find the part number for the correct key fob.. then cross that number with some aftermarket fobs to get what you need.. than installation is easiest done thru your stock radio
/\ even the base model came standard with keyless entry back in 01?
Wow, I didn't know that.
