1 - 11 of 11 Posts
hello i am new here and happy to have a 2002 impala ls 3800.
my problem is that when i want the air to come out of the dash vents only, it sounds like it is blowing into the dash. the flow is week, and it also comes out of the driver side floor slightly. and always seems to blow onto the windshield.
any thought or help given is greatly appreciated. happy driving.
Likely a plugged up cabin filter (under wipers on exterior of car) or possibly a vacuum leak.
Reactions: marijubud
follow the small vacuum line from the intake to the harness it runs to by the battery. sounds like you have a vacuum leak and mine was right by the battery.
sweet thanks for the help. its really annoying. ive been told i had a vacuum leak. ill look at that line asap.
Yup that's a common vacuum line to break and will cause the loss of direction control.
No, look over along the passenger fender, there is a small plastic line running from by the firewall, down to the battery, then it loops back into the wiring behind the overflow tank.
Discussion Starter · #8 ·
thanks for the input. i found what you were trying to tell me.
Auto part Vehicle Engine Car
while i didnt find a leak (im no mechanic) i did find this.
Pipe Metal Fuel line
which goes here.
Engine Vehicle Auto part Car Automotive engine part
Hose Fuel line Auto part Pipe Engine
if this is getting annoying i understand. im taking the car to the mechanic on thursday. thank you for the help. i am having multiple problems only a year and a half into ownership and only 118k miles.
Marijubud, I'm sorry you've been experiencing these concerns! If you would like any assistance working with your Chevrolet dealer towards a resolution, please don't hesitate to let me know. I'm available via private message on the forum and happy to research your best next steps with you whenever you want.
Best,
Katie
Chevrolet Customer Service
That box the wire is going to is the cruise control, so while it is an issue, it appears to be a separate one.
Discussion Starter · #11 ·
Well, my cruise works. So I'm not worried about it too much. Thanks for the info.
1 - 11 of 11 Posts
