In an effort to stay ahead of a pending possible trans failure issue, I am interested in knowing if an auto trans from say a 2004 or 2005 3.8 equipped Impala would be a direct swap into my 2000 3.8 Impala? Any parts compatibility concerns with such a swap? If this swap is not doable, can someone tell me what year trans will work? Also I was told that the 2000 model does not have a hardened output shaft??? They started using them in later years, can anyone comment on that?
Thanks.
Ken.
Really, nothing at all?? Allllllrighty then, thanks anyway.
Thanks.
Ken.
Has to be the same model & gear ratio
as long as it has that it should be fine
