the a/c quit working, the lights on the a/c panel dont come on, fuse is good, what is the problem?
its possible the main inside control unit has went out on it,first make absolutely sure the fuse hasn't blown for the air conditioner,its going to be a bigger one than the rest ,it acts more like a breaker and they will go bad and not re-set ,and there is a fuse for the fan that blows the air out,if all this is good pull the unit out and check to see if the wires are on it real good,sometime they,ll shake loose,and cause this,good luck.
