Thanks for the compliment, here are the picsYou need to post up some pics of your '94 Fleetwood!
That car is B-E-A-U-T-I-F-U-L!!!!!
I know nothing about air bags...
AND, I wasn't a fan of wires...
Until NOW!
These two Fleetwoods are AMAZING! :biggrin:
i have a 94 Buick Roadmaster bagged on 20's, why you need so much air is beyond me, you must be using the smallest bags ever made, i run Slam Specialties RE7's up front and my ride height is 80psi, in the rear i have Firestone 2600lb bags and i run 40 psi there for good ride height, thats not to say i can cruise over speed bumps, i go to about 90 front and 60 rear for speed bumpsWhat size bags did you use in the front?
My fleet is bagged too but I think they used bags that are too small in the front because i need at least 160 PSI to lift the front. I know the front is heavier and everything but the rears will lift with as little as 120 psi. I know the bigger the bag the less pressure it takes to lift, right?
