1 - 14 of 14 Posts
Went it go to the store this morning and my '96 with the 4.3 wouldn't start
It will turn over, but wont run. I took the battery out and had it tested and its fine. I drove the car yesterday and it was fine. The CEL isn't on. Anybody have any ideas what it could be? Thanks in advanced!
Adam
Have you checked things like the fuel pump fuse?
How mechanically comfortable are you?
Fuse is in the underhood fuse box by the passenger hood hinge.
Swapped out the fuse and the relay with no luck. Pretty sure the fuel pump is shot. Just had it towed to a buddies shop. Thanks for the help.
Adam
Have you checked for spark?
Discussion Starter #8
Tried both sets of keys and both worked. Didnt check for spark, but we couldn't hear the fule pump at all,
Discussion Starter #9
Well, its definitely the fuel pump. Its getting changed out as I type too the tune of $500-$1000 depending how everything comes out.
Ouch, that's why most of us are DIY.
Discussion Starter #11
I usually am a DIY'er, but I just don't have the time this week. Work is crazy and I'm putting in between 12-15hrs a day. I just need it fixed and fixed right at this point.
The tank is super easy to drop so long as you can empty it.
With a lift I can not see it taking an hour and a half TOPS and that is if they find some rust and crap to deal with.
A stock pump is not expensive upgrades one with upgrade relays and wiring are under $200.
IMO $500 including a short distance tow is robbery.
All data calls for 1.8 hours on the labor. Other labor guides have it slightly higher. I have dropped the tank, and put it back up well under two hours. This was doing it on the ground, with it 1/4 full. By myself. Even on my rusted out 95 RMS, it still didn't take more than two hours. I think as of right now, I have dropped and re installed the tank on 6 of my cars. A few of them, I was just playing musical gas tanks, or installing an after market fuel pump.
You can actually get a hose down the fill tube to drain these most of the way. I have used the cheap hand pump they sell at autozone, and it worked good enough for me with an extension of hose on the output. Autozone sells a pump for $80, and I know I have seen delphi/ borg warner pumps in the same price range.
So... 2 hours labor at 80/hr($160), plus a fuel pump for $115(lets assume they mark parts up 40%), that's only $275. Now, many times the wiring is fried on these inside the sending unit, but that's only another $50, tops.
bro i bought one off ebay for 24 buck delivered !!! and dropped the tank and installed in 45 min . ofcourse between the pump getting there i unplugged the wireing harness and spaced i did it and spent a week trying to track down the "electrical problem "before realizing my mistake . shit . i'll do it for ya .
1 - 14 of 14 Posts
