I recently bought a '95 Caprice with the 5.7L lt1. Everything was working fine until this morning when I go to turn the car on. It turns on but the cluster is out, the ac won't turn on, and the power windows don't work. The radio still works. All of that worked prior to this morning. I changed the interior fuses associated with those things- numbers 11, 17, 33, and 42 and still nothing. Please help!
It's a common problem with the cluster if u was to bang on the dashboard dose it come back on if so remove the cluster and clean the electrical contact points
Your problem is a poor ground connection. Looks for a ground splice (a gang of wires connected together) probably near the drivers kick panel. Corrosion is a big factor especially if the car experienced a flood
