Two questions. I have a 94 sedan limited. The abs light is on and the abs doesnt work. I just did the front end brakes-pads, bearings, etc. I need to get it fixed because this boat in the snow is horrible while braking and i need all the help i can get. Also when i tried to run a engine code with the jumper the codes dont come out. Both of the fans turn on and the check engine light stays off. If i take the jumper out the fans turn off and the check engine light comes on. Any help would be greatly appreciated. Thanks.
