I Have A 94 Imp And The Car Will Not Stay Running Unless I Turn On The Flashers My Didital Dash Is Not Coming On Untill I Turn On The Lights But If I Turn On The Lights The Car Will Shut Down I Have No Lights In The Back Of The Car At All This Just Happened Today But The Car Was Fine Yesterday I Also Have A Viper Alarm Sys In The Car And I Unplugged The Brain And The Car Still Did The Same Thing Please Help Me Im In Need
wow
good lock, that saund like if you where just joaking.
i will first check the battery cables including the battery ground then i will check that every ground cable that attaches to the car body is tight and in good conditions ,then i'll go for the ignition switch .?????????
o and check the rear tail lights for broken cables or relay.
Remove Ur Aftermaket Alarm System They Mess These Car Up But If U Have Already Dome That Then Idk My Blinkers Act Wierd Sometimes To
