I had an electric antenna installed at Circuit City for my SUV. I threw the old one away. Cost a little over $100 for antenna and installation. Check them out. But first do the following yourself.
Get a paper Towel and a can of WD40.
Spray the antenna.
manually force the antenna up or down using the towel, the antenna is stuck most likely in either the up or down position.
Use some force to move it but not enough to bend it.
You may have to spray it 3 or 4 times. Turn off your radio so the motor wont run then turn it on until the antenna starts to work.
If you can't get it to work...............Circuit City is your best bet.
