1 - 20 of 34 Posts
Whenever I go to fill up my car with gas the gas pumps always automatically shut themselves off too early. I've tried pulling the nozzle out in various positions. I've also tried to just hold it on with my hand and it still shuts off too soon. I'm thinking it has to do with a clogged vent hose or something along those lines. Any further direction would be great.
Luke
Wow, how'd you get your hands on a 9 gen? jk lol
What year is it?
PS I assume you got this off Wiki? They're wrong.
Probably clogged evap canister purge, check engine light?
this happens to me too. it didnt happen at all while i was living in Ohio. and as soon as i moved to Georgia it started happening. i just assumed that the pumps here pump faster or more forceful than up there and the air not being able to escape the tank fast enough not allowing the gas to flow down as it should, hence the pump stopping early. hella annoying when it happens like every 80 cents or so :/
Damn Wiki. Idiots.
I'm assuming this is 8th Gen, 2006-11. Please let me know if I'm wrong.
Gas pumps turn off automagically when the nozzle gets liquid on the outside, don't ask me how it knows the difference, but it does, this happens to keep gas from spilling out on the ground from assheads that insist on putting their gas caps in the handle....most likely it's a problem with the pumps the guy was using, not the car itself....or there's a problem with the screen and it's allowing gas to backup at the nozzle....
I know, I know the OP prolly won't be back, but still, fyi for everyone else I guess..
Discussion Starter #11
If it's a clogged vent hose how do I know which one? I looked by the gas tank and there is what looks like a vent hose but it's attached to the filler hose and it looks like the only way to disconnect it is to cut it off. Also, there looks to be an evaporation canister down by the gas tank. Is that the right one?
Yes, its the canister by the tank. Attached to it is the evap canister purge valve, if it gets stuck closed it can cause the problem you are having. I would honestly expect you to have a check engine light in that case, but not necessarily so. 2008 might still be under warranty, I guess it depends on when you bought it and how many miles are on it, but if it is let the dealer sort it out. Otherwise, its only a $30-40 part anyway.
SStuntin on em
the putting the gas cap in the handle thing you mentioned. is that to keep it pumping?
oh yeah and, as the gas level in the tank rises, the distance between the dispenser nozzle and the fuel grows smaller. A small pipe called a venturi runs alongside the gas nozzle. When the end of the venturi pipe becomes submerged in the rising gas, it chokes off the air pressure that holds the nozzle handle open and shuts down the flow of gas. Unfortunately, this shutdown can sometimes happen before the tank is full as the rapidly flowing gas backs up on its way into the tank. This can cause the gas handle to spring open before pumping is complete, leaving the annoyed customer to squeeze the handle again. Pausing briefly will allow the gas to continue into the tank and the pump nozzle to start pouring gas again.
yes....and it pisses me off to no end when people do this, I mean seriously, how lazy do you have to be when holding the handle is too much work??!!??
Our handles have latches built in that you can use, it still stops by itself.
does the handle not stay up in NY? cuz it does in the Chi
They used to, but now it's against the law, so is putting your gas cap in them, as well as talking on the phone, could cause a spark and blow the place up, there's a few others, been a while since I read the sign at the pumps...I think everyone has the no smoking law, however I have still seen some people doing it..
SStuntin on em
oh that has to suck in the winter. but yeah i know getting in and out of the car creates static which will make a spark, im pretty sure on the signs it says not to leave the car on. not sure tho
yeah, but again, in the winter, you will see people leave them on anyways...haha, I dunno, I just wear gloves in the winter time, or switch hands and keep one in my pocket, or just time my fill ups so that when it's OMG degrees, I just don't fill up, but that requires stalking the weather forecast..sometimes I just fill up a little bit to get me where I need to be..
1 - 20 of 34 Posts
