7th Gen thermostat easy way
1222 Views 1 Reply 2 Participants Last post by  Davec2008
9
I've seen lots of post about changing the thermostat, which is a pain to get to. I'll show you an easy way to do this without fighting the exhaust crossover removal and lower housing bolt.. Time=about 1-1.5 hrs. You might get a new TB gasket first. Got mine at O'Rileys for under $2.00 part # 61503 and it's a fel-Pro..
pic1=A pic of the part no and gasket for throttle body
Pic2=you need to disconnect wiring to areas in red. There are a few other things attached to throttle body on top and the cables to throttle and trans.
pic3=Shows the heating hoses attached to unit
pic4=Shows the location of bottom bolt which also holds the bypass tube in place. Also the throttle body heat disconnected.
pic5=View of thermostat housing with throttle body removed
pic6=Shows access to lower housing 13mm bolt. I put a rag under housing as shown in next pic first to catch bolt in case you drop it.
pic7=Here you see the rag in place.
pic8=After loosening you can get to it with fingers.
pic9=Exposing the thermostat (already removed) and where it goes..
Engine Auto part Vehicle Car Automotive engine part
Auto part Engine Motor vehicle Fuel line Vehicle
Auto part Engine Fuel line Vehicle Car
Auto part Fuel line Pipe Engine Automotive fuel system
Auto part Engine
Auto part Engine Pipe Automotive engine part
Auto part Engine
Auto part Engine Fish
See less See more
Is that a 3.4?
