does anyone know where i can buy a conversion kit for a 77 impala. i need to replace the rear drums to disc.... thanks
yea i thought about all the other parts that i need to change... money at this point is not an option, this car is already beign rebuilt from the frame and up. im already changing everything. its going to be a show car so the newer things i put the better.
Might consider an axle from a 94-96 Impala or 9C1 as those got discs, and being a factory setup parts are easy and relatively cheap. Also gives you a nice strong 30-spline 8.5" strong as a 12-bolt.
Not sure if the brakes from those would retrofit to your axle or not.
