My Caprice runs real good @ idle, real smooth. I've put in new points/condenser/rotor/cap/spark plugs @ .35 . Dwell is at 29 degrees. Checked the timing + it's at factory spec. I sprayed WD 40 all around manifold & vac. hoses. Don't seem to have a vacuum issue.
If I put a load on the motor - It sputters & little popping (backfires) occur out of the exaust. Could it be the Coil is going bad? Seems like the more RPM'S I get -then it goes away...??
At night - I have noticed a slight flicker of the headlights & Alternator may be going bad...
I'm trying to avoid buying parts - I don't need.
Any Advice?
Thanks,
Mark in Kansas.:dunno::dunno::dunno::dunno::dizzy:
Any Advice?
Thanks,
