I need a source to replace a rotted out tranny crossmember for my 69 Impala. Seems I can't find a source on the interweb or I'm looking in all the wrong places. it has a 396 stock in it with a TH400 transmission. I need a new crossmember to bolt into the area where the old one will be removed.
I had believed that all the Crossmembers were the same, Powerglide, TH350 and TH400 and upon a quick online search, that "seems" to be true.
The difference between the PG and TH350 one and the TH400 one is where they are located at. The TH400 needs to be bolted in the Rear location of the Bracket on the frame rails. Only TH400 cars had Brackets for both positions.
That said, I have some '65 to '70 Crossmembers available, including one still in a '68 Impala, factory 327 and TH400.
Bill
