Hi all --
I just swapped my 69 Impala 350's PG for a 700R4. Used the Lokar shift linkage, the B&M Lockup controller, and modified the original crossmember and shaft for the install.
The shifter works great, but of course the pattern is different, so the Neutral Safety Switch is wrong -- it starts in Park and 3rd gear, and the reverse lights are on when the 700R4 is in Drive.
Here's my question -- can the original PG safety switch be adjusted for the 700R4, or do I need a different NSS? If I need a different one...any ideas as to what will work?
Thanks in advance.
Hi all --
Thanks in advance.
I know it maybe a long shot but I have 66 impala 4dr and was looking for thenlenght of the driveshaft from the transmission to the diff as im going to a 700r4 too. Do you by chance have the length of what you used I don't have a shop close by that will even look or even do this work. Thank Mike
