Hey guys! Had a few questions on my 66 Caprice with the 396 engine. I’m trying to find the correct bolt to land the negative battery cable to my engine block. Does anyone know where I can find the correct bolt? Haven’t had any luck searching online.
165076
Also, I’m wondering if I’m missing any springs for my throttle or throttle return springs. The gas pedal seems to get a little stuck when revving the engine. I’m hoping someone will be able to tell by the pictures. I tried looking at pictures of the same engine but haven’t been able to tell.
165077
165078
Appreciate the help!
You can find a "Shouldered Hex Bolt" with the standard threads at ACE™ Hardware.
While shopping for the Ground Strap; check-out their selection of Universal Return Springs.
If you want to be a little daring with hooking-up that Ground Strap; have them show you something in a Black Socket Head, Cap Screw or Allen Head Bolt to hold that Ground wire.
Reactions: Ygrmstrr
