I have yet to figure out how to fill my hydraulic system for the top!
please help.
i know the pump is behind the back seat. there is no resivor i can see. jsut steight from the pump to the (lifting rods) i forgot the term. but anyway it works, just not enough fluid and needs assistance , i disconected the lines and ran all the old ATF or whatever was in there out.
if u know how to go about filling these please let me know!
There is a plug on the side of the pump. You have to remove the plug and fill the internal reservoir. Operate the pump motor up and down. The system will generally bleed itself. Keep adding fluid until the top operates smoothly. If you have problems or don't feel comfortable doing it, find a trim and upholstery shop near you. They will be able to take care of it for you. I hope this helps.
