1 - 8 of 8 Posts
Hi Can any one tell me the bolt pattern on a 1962 Chev Impala
It has 5 studs so it would 5 x ????
17" x 8 Rim diameter
Thanks
it's a 4 ¾" bolt circle diameter, if measured from stud across to stud it's about 4½", I usually measure the radius, from center of stud to center of wheel and multiply by 2.
62 bolt pattern
Your '62 has a 4.75" bolt pattern. The way to measure is from the back of hole to the center of the second hole.
It also has 3.75" back spacing, which is important when purchasing new wheels.
15" wheels work out real nice on these cars.
Good luck with your project.
5 X 4.75 is correct
1 - 8 of 8 Posts
