Hello everyone. I have a 61 belair that still has the original 6cyl with 3 speed on the column. I am looking to swap to a 350 small block. I am told it will mate up to the 3speed trans. Im assuming ill need a new flywheel to make this work. Any info on this will be greatly appreciated! Thanks
You will need a new Bell Housing too. The '61 6-Cylinder Bell is too small. You will also need V-8 Engine Frame Mounts as well.
