'59 Two Tone Paint Decode
326 Views 1 Reply 2 Participants Last post by  sheila
10
Trying to decode cowl tag for correct two tone paint. From info I've researched I believe it indicates Snowcrest White over Crown Sapphire Metallic, and interior trim code is turquoise cloth and vinyl. The body was already primed when I got it, but original inside door jambs appear to be a lighter blue than even Frost Blue according to the paint chip chart. Also the interior appears to be blue and white instead of turquoise and white. I'm just concerned if I order the Crown Sapphire and it definitely doesn't match the door jambs. No real biggie, I just want it to be correct per the cowl tag. Any advice would be appreciated.
Automotive tire Motor vehicle Hood Vehicle door Bumper
Car Vehicle Motor vehicle Fixture Steering wheel
Rectangle Font Material property Parallel Pattern
Plant Font Gas Wood Grass
Rectangle Font Parallel Screenshot Software
See less See more
Reactions: 1
May check over at Impala.net.
Reactions: 1
