So im trying to find out the difference between the 2 as far as gearing and shift points.... Im in the process of get another trans to rebuilt it so i can put in my car.... I found a HD hud type thing for the 4t65e on zzperformance site but I just need some input and other ideas from you guys thanks.....
Yes the hd diff is slighty larger and is not a true 1:1 ratio set up. So if you put an hd diff in you're impala it would change the final drive ratio from 3.05s to 3.29s.
So as far as the power band goes is that going to change how the power drops at 90 mph or stay the same.... Also is that a good idea on going as far as building a 4t65e-hd and later on get the l67 and the throw it in..... Right about now my current trans is starting to give me even more problems..
