1 - 15 of 15 Posts
So 235/50/18 are the 'stock size' for 18s but I was wondering how the 245/45/18 would compare. What are the pros to each size?
245/50/18 = 9.64 wide
Rim Width Range is 7 - 8.5"
27.64 Diam
4.82 Sidewall
86.83 Circumference
725.5 Rev's per mile
60 MPH true
245/45/18 = 9.64 wide
Rim Width Range is 7.5 - 9 "
26.68 Diam
4.34 Sidewall
83.81 Circumference
779.6 Rev's permile
62.1 MPH
Speedometer 3.6% too fast
Diameter difference is 3.46%
HTH
Paul
This has been recommended to me by several tire and mag guys that I have dealt with.
That possible typo confuses the hell out of me Paul!
245/45's are alot cheaper cause it's a more "common" size than the 235/50's. I've been running 245/45's for about 4yrs now. Your speedo will read 2mph faster, but thats not a bad thing!
Holy Crap !!!!!!!!
Don't know WTF happened there
let me try this one more time
Sorry
235/50/18
Width 9.25
Rim Width Range 6.5 - 8.5"
Overall Diameter 27.25 "
Sidewall Height 4.62 "
Radius 13.62 "
Circumference 85.60"
Revs Per Mile 763.3
60 MPH True
245/45/18
Width 9.64"
Rim Width Range 7.5 - 9"
Overall Diameter 26.68"
Sidewalll height 4.34"
Radius 13.34"
Circumference 83.81"
Rev Per Mile 779.6
Speed 61.2 MPH
Speedo Difference 2.135% too fast
Diameter Difference 2.1%
Looks like there are 14 or 15 more manufacturers/choices for the 45's as well.
Damn, you guys are awesome. I bet they would be a bit cheaper.
I kind of like the look of the smaller wheel with my black rims, especially since I've lowered it.
That is usually the case with low profile tires.
Higher the sidewall the better the ride, but you lose performance the taller you go.
You can't really call a 245/45 a low pro tire when switching from 235/50. The ride quality doesn't suffer if you spend some decent money on tires. Now if you buy some $30 flea market tires then yes you could blame a shit ride on the 245/45 I guess.
I guess I made that comment "Sidewall height In General" not meaning to compare the two sizes that were mentioned here.
The 45 is "lower profile" than the 50 but only by 1/4 " +/-.
In this case you do lose approx a 1/4 inch of "cushion" going to the 45
I was meaning that a 60 or 65 series will ride nicer than a 45 or 50, and the 45 - 50's will be nicer than a 25 or 30 where the sidewall is getting down under 3 inches.
Might as well drive around on hollowed out hockey pucks.
Paul
I posted about this very topic in the general post area, but didn't get any responses - still finding my way around the forum. Glad to see you guys having this discussion. I'm looking at the General G-Max AS-03 and the Cooper Zeon RS3-A tires in the 245/45/18 size. Judging by what I've read here, it sounds like there is no fitment issue and the size might ride just as well. I like the idea of a little more meat on the road. Have any of you guys heard anything about the tires above, or do you have any other suggestions? I put 25,000-30,000 miles a year on my car and I can't see spending the $1200-$1400 for the direct replacement Good Years. I need good tires that are going to be quiet, comfortable, and last 50,000+ miles. Also, have you seen any noticeable change in the gas mileage with the 45's? I would think with slightly less diameter, lighter weight, and slightly lower ride on the car, it might make a small improvement. I'd also like to upgrade the front shocks/struts to eliminate some of the roll in turns, but don't want to make the car too harsh - I know something about wanting cake and eating it too, right... Any suggestions there?
Can I put a P245/55/R18 on my 2012 LTZ?
Ill advised to do so... Too tall aspect ratio so the speedo will be off big time. Do a 245/45-18 or stay with the 235/50-18. I'm not sure if the stock LTZ wheels can even do a 245/45 safely.
1 - 15 of 15 Posts
