21 - 23 of 23 Posts
9005 hb3. Think I'm gonna try it. Gotta figure out how to get the filler tube out. Can't find a video shows it. Only one I seen shows a guy tearing most the front off the car.
All you have to do to get the filler tube out is pull straight up on it. The LEDs will fit.
Owners manual shows you how to replace headlight bulbs.
The Morimoto 2 stroke 2.0 bulbs fit behind the cap easily. I mentioned I needed the anti flicker harness though, so for that I had to cut a hole in the caps to have the wires come out and placed the resistor module outside of the headlight because it gets very hot.
If you get a bulb that doesn't require that and isn't as huge as Pelosi's face then you should be good with it fitting.
21 - 23 of 23 Posts
