I purchased recently this sedan; Unfortunately it takes "force" to close the trunk. (Very noisy)
Is there a way to change this issue?
With my older sedan, the trunk was easy to close.
Thank you!
Thank you!
TTY,
Do you mead "Force" as in hard to pull the trunk lid down, or "Force" as in hard to get the lid to latch? If hard to latch, you may need to adjust the height of the striker on the inside of the lower trunk lip. If hard to pull lid down, you may need to lubricate the pivot points on the trunk hinges (WD-40).
Dave
Problem with the trunk issue is solved!
Dave, thank you for your reply
