I have that same problem
Same problem With our 2016 Impala. Noticed musty smell, 2 inches if stagnant water In trunk wheel well.
Have a 2016 Impala LS, right rear tail lamp assembly is leaking, have water in the spare wheel compt. I have removed the 2 plastic cargo net holders, removed the clip on the trunk trim and pulled out of the way, Removed the 4 5/16" nuts holding assembly in place, disconnected lamp wiring. But cannot get the lamp assembly to come out. Almost as if the bumper is preventing it from coming out. Really don't want to take it to a dealer since $$ is tight. Am I missing something? Need to get this fixed with all the rain we are getting here in Western WA!!! Thanks
Yes it does help as I finally have a dry day to replace it. Appreciate it!Was post #9 helpful?
Also found 3 torx screws holding the bottom of tail light assy to the bumper fascia, what a pain! But got it done now to get some damp rid and try to get any moisture out of the liner and the musty smell. Again Thanks Oh and it was 6mm bolt but no problem!Good luck - the removal of the sides of the bumper fascia are not hard - but sometimes seem like they are stuck when you begin to pull them away from the rear quarter panels.
Greetings - I was so excited to purchase my 2019 Chevy Impala two months ago, only to learn that today I have all this water in the spare tire compartment. I was actually in the trunk area trying to locate the antenna for the keyless entry exterior door handle that stop working last week. I can only unlock door using the key fob. Now, I learned about the standing water.
I removed the water and dried the area. If my car is certified pre-owned will this be covered by GM? Should I consider taking to the dealer or independent mechanic?
Multiple issues in play....
