21 - 22 of 22 Posts
I had a 2012 impala before with the same setup and never experienced a problem with it. I went to the dealer yesterday and bought a 2015 with 54,000 miles on it. I was on my way home and noticed a shuddering when going up hills and a slight hesitation in changing gears. The car is back at the dealer now and they are apparently replacing the transmission. Is this common, or did I just buy a lemon?
My take is, when it's covered under warranty, the dealers tend to swap transmissions rather than repair them. So it might have been something relatively simple, such as a problem with control of the lock up torque converter. They probably could have repaired it, but by swapping it out with a factory re-man unit that's been tested, they have higher confidence in the repair.
My opinion is that to get the good gas mileage the computer is always looking for optium gear, therefore it shifts a lot. I don't think you will get rid of this, it is normal. If it only had 2 or 3 speeds it wouldn't shift as much OR GET AS GOOD OF GAS MILEAGE.
21 - 22 of 22 Posts
