How do you remove the chome emblem that has Impala on it. I've removed the 2 nut's on the inside and I see it has the plastic clips on it (several). Can I pop it off with out breaking the clips.
You could try to grasp the part, and push it down (or up) gently - which would release the clips on the opposite direction that you ar pushing. Then, when one edge of the clips release - tilt out slightly and left away, releasing the other clips.
