1 - 10 of 10 Posts
This is an Idea
for those who want to
Make their Impala
Look like New.
Swap the
Hood, Fenders, Grille & Bumper
from a 2014 & Newer Impala
to a 2006 to 2012 Impala.
The Front end sheet metal
sure Looks Sharp
much like a 2010 & Newer Camaro.
If you work in
a Junkyard or Body Shop
or have access to both body style
perhaps You can be the First
to Do this Swap
and let us know
what Needs to be done
to Make Impalas
Look Sharp.
Discussion Starter #2
This could be a good Business
for someone,
since this generation of Impalas
are basically the Same
from 2006 to 2017.
12 years
is a big Market for Aftermarket
either making used parts fit
or
finding or financing
a company to make the Sheet metal
so Parts Bolt on.
This is an Idea
Make their Impala
Look like New.
Swap the
sure Looks Sharp
If you work in
to Do this Swap
and let us know
to Make Impalas
Look Sharp.
You should do this and then post pictures.
I still think the original poster should give it a try. It might also be fun to swap a new body style backend, interior, frame, and side doors onto an old body style eighth generation.
I see this not going anywhere lol, the 2014 impala vs the '06 to '13 may as well be a totally different car.
The 2006 to 2017 8th gen body is basically the same car with a few exceptions, most notably the 3.6L engine in 2012 and 6-speed transmission. In 2014 the 9th gen Impalas started production, but Chevy still makes the 8th gens 'Limited.' :)
OP: EarlT500
Swap the
2014 & newer implies the current gen and is how I read the post.
The biggest problem will be that the cars are on two entirely different platforms. The 06-16 Limited is W-Body and the 14+ is Epsilon II. Notably the fuel doors are on opposite sides, so the back cannot be swapped easily. The front would depend on overall dimensions.
exactly as I read it. can't blame op for being curious but it'd be easier to just get a 14+ model and call it a day.
1 - 10 of 10 Posts
