evey time I drive some where I have to pop hood let under hood cool before starting car wont crank it hot I changed battery and starter to try and fix problem but still no luck....
I had this problem with my 2009 Impala. Check to make sure you cooling fans behind the radiator are working. If not, replace fuses on the fuse block under the hood. My 2014 Limited hasn’t had this problem yet, but it’s the same setup.
