In case anyone has been living under an automotive rock... :lol: I figured i'd give everyone a chance to see the next American Supercar! I present, the 2012 Hennessey Venom GT!
Performance
0 – 60 mph 2.5 sec.
1/4 Mile 9.9 sec. @ 162 mph
0 – 200 mph 15.9 sec. (Bugatti Veyron = 24.2 sec.)
Top Speed 275 mph
Power
Horsepower 1,200 bhp @ 6,500 rpm
Torque 1,155 lb-ft @ 4,200 rpm
Specific Output 166 bhp / Liter
Bhp / Weight 767.23 hp per ton or 2.61 lbs / hp
Boost 16 psi (1.1 bar)
Fuel 93 octane
Engine
Type V8
Block Aluminum
Size 376 CID (6.2 Liter)
Position Mid Longitudinal
Compression 8.8:1
Redline 7,200 rpm
Forced Induction Twin Garrett Ball Bearing Turbochargers
Oiling System Dry Sump Lubrication
Fuel System Sequential Multi-Port Electronic Fuel Injection
Transmission
Type Ricardo 6-Speed Manual
Gear Ratios 2.61:1, 1.71:1, 1.23:1, 0.94:1, 0.77:1, 0.63:1
Final Drive 3.36:1
Brakes
Calipers Brembo 6-Piston (all four corners)
Rotors 15.0 x 1.34 in. Carbon Ceramic (all four corners)
Suspension
Type KW Variant 3 Adjustable Coilover (all four corners)
Ride Height Adjustable by 2.4 inches (60 mm)
Dimensions
Length 15.27 ft. (4,655 mm)
Width 6.43 ft. (1,960 mm)
Wheelbase 110.24 in. (2,800 mm)
Track – Front 63.46 in. (1,612 mm)
Track – Rear 63.15 in. (1,604 mm)
Body
Material Carbon fiber composite except doors & roof
Type 2-door
Weights & Measures
Curb Weight 2,685 lbs (1,220 kilo)
Dry Weight 2,524 lbs (1,147 kilo)
F / R Balance 37 / 63 (empty); 44 / 56 (with driver & passenger)
Fuel Capacity 18.5 gal. (70 Liter)
Wheels & Tires
Tire – Front 255/30/20 Michelin Pilot Super Sport
Tire – Rear 345/30/20 Michelin Pilot Super Sport
Wheel – Front 9.5 x 20 in.
Wheel – Rear 12.5 x 20 in.
^YES THAT'S A 270 MPH GAUGE... NOT JUST FOR SHOW
:WTF:^
I realize some haters out there might say that it's not a true American supercar because it's in a Lotus body.. The reality is there isn't much Lotus left. The body has been changed to carbon fiber, widened a ton and also lengthened. It is also running a Chevrolet motor, and will soon be running a Ford transmission (out of the Ford GT). So this is, without a doubt, our all american Bugatti killer!
k3:
FYI, for those who would like to order, start saving now because it even has a supercar price... of $900k. So if you have the money for this then these smilies are for you! lol
:notworthy: :wav: :notworthy:
Performance
0 – 60 mph 2.5 sec.
Top Speed 275 mph
Power
Fuel 93 octane
Engine
Type V8
Block Aluminum
Compression 8.8:1
Redline 7,200 rpm
Transmission
Final Drive 3.36:1
Brakes
Suspension
Dimensions
Body
Type 2-door
Weights & Measures
Wheels & Tires
